no compression
Old Apr 13, 2003 | 11:11 PM
altima/240sx's Avatar
no compression
here's the deal, i was coming home from a party at Akron U. and on the way home, a Caprise Classid decided to try to race me. I was always pulling on him until i let up off the gas. at one point, i shifted into 3rd on the highway, and was trying to shift into 4th, but went into 2nd by accident. this caused me to either bend a valve, or somehow the exhaust valve in cylinder 2 is stuck open. so i get no compression. is there a way to fix this without taking the head off, or do i have to get a head job. all other cylinders are at at least 130PSI in a compression test.
Old Apr 13, 2003 | 11:28 PM
Strizzy's Avatar
pop off the valve cover and check for a rocker that may be poped to one side, this happend to me in my eclipse before.
Old Apr 13, 2003 | 11:30 PM
the exhaust valve on cylinder 2 is definately off trac. But Im use to working on the DOHC motor, Im not sure how to try to adjust or change the valves on a SOHC motor. plus the rocker on that valve is loose too. i can move it by hand. all the other rockers are stiff and can't be moved. i hope i don't have to get a valve job and take the head off, but if i have to, i guess i will.
fastback240sx
Oct 4, 2003 08:25 PM
DaydreamDrifter
Aug 18, 2003 10:05 AM
240baja
Feb 16, 2003 01:19 PM
agressiveracing
Northeast
Oct 30, 2002 09:27 AM
rbboyl
Sep 24, 2002 10:02 PM
