Power steering mishap
Old Apr 25, 2007 | 11:06 AM
Clarke240's Avatar
So my power steering went out on me 2 days ago, it sprang a pretty good leak and drained all of the fluid out. Should I refill with power steering fluid or ATF as I read on someone elses thread?
Old Apr 25, 2007 | 01:23 PM
Scuderia's Avatar
I just went through this because I didn't RTFM. (Read The F*ck!ng Manual)
ATF only. DO NOT put anything else in or you will not like the results.
Make sure you clean off all of the old fluid and grease before refilling so that when you start your lock-to-lock air bleed you can see new leaks.
Old Apr 25, 2007 | 02:02 PM
positron's Avatar
Find out where the leak is and fix it or it's just going to happen again.
Bryan
Jan 24, 2006 11:54 AM
JDMxDrift
Mar 5, 2005 01:50 PM
rbboyl
Apr 21, 2003 03:12 AM
cjm93240sx
Apr 12, 2003 10:11 PM
SilvaPwr
Sep 23, 2002 04:29 PM
