pulley installation
just wondering how extensive a job it is to put in aftermarket pulleys. is it just a quick swap? or a big deal to take everything off?
maybe like 30-60min if youve never done it
I installed an under drive pulley last year, and it was well worth it! I used a piece of wood to slowly work of the old pulley without much force. The new pulley slid on quite easily.
The only problem I had, was the front main seal rubbed on the new pulley and burnt a hole in it. So I had to remove it again, replaced the front main seal and reinstalled the pulley. Make a note to push the front main seal in a little bit further to avoid it from rubbing. You'll know if you burnt a hole in it, if oil is thrown all over under the hood. Good Luck! |
it is pretty easy of an install like stated above... in addition to pushing in the front seal i would replace it at the time of a pully swap... after all the hard part of removing the pully is already done and it would only take a few seconds to install a 5 dollar seal...
