pulley installation
Old Sep 4, 2006 | 05:50 PM
iceman4's Avatar
pulley installation
just wondering how extensive a job it is to put in aftermarket pulleys. is it just a quick swap? or a big deal to take everything off?
Old Sep 4, 2006 | 06:08 PM
maybe like 30-60min if youve never done it
Old Sep 4, 2006 | 08:03 PM
trevr's Avatar
I installed an under drive pulley last year, and it was well worth it! I used a piece of wood to slowly work of the old pulley without much force. The new pulley slid on quite easily.
The only problem I had, was the front main seal rubbed on the new pulley and burnt a hole in it. So I had to remove it again, replaced the front main seal and reinstalled the pulley.
Make a note to push the front main seal in a little bit further to avoid it from rubbing. You'll know if you burnt a hole in it, if oil is thrown all over under the hood.
Good Luck!
Old Sep 5, 2006 | 06:16 PM
wikd240's Avatar
it is pretty easy of an install like stated above... in addition to pushing in the front seal i would replace it at the time of a pully swap... after all the hard part of removing the pully is already done and it would only take a few seconds to install a 5 dollar seal...
craigkiel
Apr 3, 2004 08:58 PM
tenggis
Dec 16, 2003 09:40 AM
focalguy
Sep 3, 2003 05:23 AM
importer9
Jun 21, 2003 01:22 AM
raf2485
Jan 20, 2003 09:46 AM
