Rough idle at startup
hey guys my 1990 240 at startup now it wants to die after sitting for a little bit. It idles rough then sometimes dies. After i hold it at like 2 grand for a little it is okay. This is only at start up though. Any clue on what i should do to fix this. thanks
You may want to check the timing setting. Had a friend with a S14 who messed around with his timing and experienced similar problems.
It may also be a sensor problem...I had this an idle problem and it turned out to be a bad sensor on the TB (the one that operatered my cruise control). Hope this helps. I may be talking out of my @ss but those are a couple of problems that I've seen with idle issues.
BlackZenki82
SR
Jun 5, 2009 09:08 AM
