Rough idle..any suggestions?
It started just last week as I would be at idle and the idle would start to fluctate a lil. Rough idle as I came home today and the exhaust smelt like a rotten egg. I can hear the valves making a lil noise and it sounds like I might have to pull off the vavlve cover to do a lil investigating. The EGR valve sounds like a good place to start and inspect. Any other suggestions?
I changed my sparks, fuel filter, and did a SEAFOAM cleaning into the crankscase, fuel tank and brake booster hose! IDLE improved, but still need to rev it right when it starts, and idle is still jumpy when slowing down but it is steady at 800rpms when stopped so. It helps. I am gonna change out my O2 sensor, and besides from that I dunno what else to try to fix it except adjust the idle on the motor itself
Depending upon how rough the idle is you could have one of your cylinders not working. this happened to my car once because somehow water got in it from washing my car and stopped it from working so it shook at idle like a crappy muscle car that hasn't been takin care of, i guess you could check that too... just a suggestion.
-Tom
-Tom
well I cleaned the maf again and pured some more seafoam. Changed the cap and rotor after checking the plugs. The plugs looked like they weren't getting enough spark. After changing the cap and rotor, the idle was all good. Car runs strong.
BlackZenki82
SR
Jun 5, 2009 09:08 AM
