s13 help ( dont know what to search for)
hey yall
i have been gettin some stranger things acting up on my car i bought a 240 a while ago, owner swapped the engine and apparently did 5 spd conversion also which made the reverse lights not work and speedo not work! sigh any suggestions what it can be? also when i rev the car and release the gas pedal the car stays at about 1900 rpm, then slowly lowers to idle also when i switch off the ignition the car stays on a second after?? any suggestions would be greatly appreciated. thx |
take out all of the sensors on the tranny and make sure they are good...if not, replace them..boom your reverse light and speedo should start working...if not, your ****ed :dunno: :laugh:
nope if u want the reverse light to work u need a 5 speed lower harness or run a wire from the sensor to the pulg and about the rpms u still have the auto ecu just buy a 5 speed ecu on ebay or something that will fix ur problem
so its the auto ecu that is making it keep in rev like that?
never heard of that....
What year 240 is yours? Did he swap in a SOHC motor, or DOHC motor? |
swapped 96 ka dohc engine in a 91 s13
You need to make sure that the Harness is that of the 96 Dohc. You also need the 96 ECU, make sure you have it. The Interior harness needs to be wired to the ecu harness as well. There are also three wires that need to be wired from the Plugs by your coolant reservoir to the ecu. Make sure this has been done. It took me a while to finally figure out why my engine wasn't running well because I have a 95 DOHC swapped into my 89 240sx.
