s13 help ( dont know what to search for)
Old Mar 7, 2006 | 05:23 PM
portion's Avatar
hey yall
i have been gettin some stranger things acting up on my car
i bought a 240 a while ago, owner swapped the engine and apparently did 5 spd conversion also
which made the reverse lights not work and speedo not work! sigh
any suggestions what it can be?
also when i rev the car
and release the gas pedal the car stays at about 1900 rpm, then slowly lowers to idle
also when i switch off the ignition the car stays on a second after??
any suggestions would be greatly appreciated. thx
Old Mar 7, 2006 | 06:45 PM
rocky2843's Avatar
take out all of the sensors on the tranny and make sure they are good...if not, replace them..boom your reverse light and speedo should start working...if not, your ****ed
Old Mar 7, 2006 | 06:51 PM
chiroke's Avatar
nope if u want the reverse light to work u need a 5 speed lower harness or run a wire from the sensor to the pulg and about the rpms u still have the auto ecu just buy a 5 speed ecu on ebay or something that will fix ur problem
Old Mar 8, 2006 | 05:17 AM
portion's Avatar
so its the auto ecu that is making it keep in rev like that?
Old Mar 8, 2006 | 10:32 AM
LA_phantom_240's Avatar
never heard of that....
What year 240 is yours?
Did he swap in a SOHC motor, or DOHC motor?
Old Mar 8, 2006 | 10:36 AM
portion's Avatar
swapped 96 ka dohc engine in a 91 s13
Old Mar 22, 2006 | 01:26 AM
silver240esex's Avatar
You need to make sure that the Harness is that of the 96 Dohc. You also need the 96 ECU, make sure you have it. The Interior harness needs to be wired to the ecu harness as well. There are also three wires that need to be wired from the Plugs by your coolant reservoir to the ecu. Make sure this has been done. It took me a while to finally figure out why my engine wasn't running well because I have a 95 DOHC swapped into my 89 240sx.
onelove240
Mar 22, 2008 07:50 PM
emtee
Jan 12, 2006 02:26 AM
quik240
Mar 12, 2005 02:05 PM
slo9012Vde
Feb 11, 2005 04:59 PM
ehxtahcee
Nov 17, 2004 08:36 AM
