-   NA Motor (https://www.s-chassis.com/forums/na-motor-11/)
-   -   seedometer doesnt work (https://www.s-chassis.com/forums/na-motor-11/seedometer-doesnt-work-22281/)
nick3 Apr 28, 2005 06:29 PM
my seedometer hasnt worked for a while now. i replaced the speed sensor, and the dash cluster, and still nothing. everything else works including the rpms but the mph doesnt. could it be the sensors on the tranny? thanks
drew935 May 2, 2005 04:34 PM
Time to read up on the FSM. It's only two wires from the tranny to the speedo cluster and ecu. :confused:
nick3 May 2, 2005 05:31 PM
i have a chilton, and i know where those wires are and there getting power, could it be the ecu?
drew935 May 2, 2005 06:11 PM
click on the fsm link. It's a better manual than the chiltons. But Chiltons should show you that the 2 wires. If your cel is not on then it is receiving a signal. Since your speedo gauge is not reading then follow then wires from the back of the gauage and check continuity to the ecu.
Joel SX May 3, 2005 05:56 AM
you should go to the supermarket and buy some pop corn, that should fix your "seedometer". But anyways, the signal goes to the Speedometer first then to the ECU. May its your speed sensor.
drew935 May 3, 2005 09:10 AM
you're actually right. the "seedometer" isn't reading anything because it needs some popcorn to pop. It's telling you that it's empty.:werd:
nick3 May 3, 2005 01:45 PM
"im just out of butter", im downloading fsm now. thanks
