slow response, now does not start
Old Jun 18, 2006 | 06:06 PM
Bryce's Avatar
Wondering if anyone has experience this, 91 240 all stock. Was hard to start and when it did it didn't have any throttle response. You could floor it and it would rev up really slow. We changed the fuel filter, plugs, wires, cap, and rotor. Still the same now it won't start. Has compression, spark, and fuel pressure. Removed the fuel rail from the intake and the injectors aren't squirting fuel. Any ideas? THanks
oh and does any one have a 240sx wiring guide. or does any one know where the cam sensor is on a 91 240sx
Old Jun 18, 2006 | 06:41 PM
zenkislider's Avatar
mine did this....
Old Jun 18, 2006 | 06:49 PM
onemoreblock's Avatar
and what did you do to get it back to life?
Old Jun 18, 2006 | 08:17 PM
rocky2843's Avatar
mine did too..still working on it.
Old Jun 19, 2006 | 04:58 AM
miked808's Avatar
Check grounds and ECU.
Old Jun 19, 2006 | 11:14 AM
re037's Avatar
chekc if your is dist is aligned properly and if the voltage from the maf is within spec.
Old Jun 20, 2006 | 09:59 AM
dkdeleon's Avatar
Re: slow response, now does not start
If your injectors are not getting fuel I would start with checking
the fuel pressure regulator, then, I would check my fuel pump.
then I would check injectors for pulse with a noid lite.
1on1
Apr 19, 2008 11:57 AM
trevr
Aug 10, 2006 10:02 AM
SlyGrin
Sep 9, 2004 08:07 AM
erebunialtima
Apr 7, 2004 07:02 PM
rudeboy
Nov 18, 2002 12:44 PM
