Spark Problems
Old Feb 20, 2006 | 09:13 PM
TotalDrift's Avatar
Question Spark Problems
I was driving my 1990 240sx yesterday and it all of a sudden died. I tried to start it and got nothing. after testing plugs wires and coil i determined they are all good but i am not getting anything out of the coil. Does anyone know what is goin on??
Old Feb 21, 2006 | 01:05 PM
dkdeleon's Avatar
the problem you are have'n is the wire harness that lays across your fan shroud.
check the harness for cuts from the fan hitting the harness I had this problem last year and found that a ground wire in the harness was cut from constant hitting of the fan.
hope this helps and sorry for the spelling im in a hurry.lol
Old Feb 21, 2006 | 04:24 PM
TotalDrift's Avatar
hmmm.. i did check out the harness a little bit and didnt find anything but i will go back and take the hole thing apart.. thanks a lot for the tip i hope it works
Old Feb 21, 2006 | 11:33 PM
mys13rocks's Avatar
your distrubutor took a sh*t. put your buddys distrubutor in your car to see if thats fixes the problem. should only take u 15 minutes to remove.
tip-mark the cap where the bolt is placed
Old Feb 22, 2006 | 08:53 AM
TotalDrift's Avatar
i checked for a spark right out of the coil and had nothing so i am not even getting a spark out of the distributor
Old Feb 22, 2006 | 10:18 AM
dkdeleon's Avatar
also check the power transister
Old Feb 22, 2006 | 02:10 PM
TotalDrift's Avatar
ya im pretty sure it is the ignition module so thats were im goin next hopefully it works
thegary
Sep 19, 2003 09:52 AM
focalguy
Sep 2, 2003 10:01 PM
tnd240
May 1, 2003 08:20 PM
Turboed240
Mar 19, 2003 03:04 PM
DCTperformance
Feb 4, 2003 11:39 AM
