swap questions
I am swapping a de out of a s14 into a 89 hatchback...
Is it extremely hard to splice the harness? Or would I be much better to just use a 91-94 harness and make the swap a lot simpler? Also which ecu should I use? the s14 or a 91-94 ecu? |
Re: swap questions
Originally posted by thekage I am swapping a de out of a s14 into a 89 hatchback... Is it extremely hard to splice the harness? Or would I be much better to just use a 91-94 harness and make the swap a lot simpler? Also which ecu should I use? the s14 or a 91-94 ecu? Splicing is a biotch and takes maddd hours I would just pick up the 91-94 wiring harness as well and you are good to go. |
