swap questions
swap questions
I am swapping a de out of a s14 into a 89 hatchback...
Is it extremely hard to splice the harness?
Or would I be much better to just use a 91-94 harness and make the swap a lot simpler?
Also which ecu should I use? the s14 or a 91-94 ecu?
Re: swap questions
Splicing is a biotch and takes maddd hours I would just pick up the 91-94 wiring harness as well and you are good to go.
Clarke240
Sep 25, 2007 03:38 PM
SilviaJai
Sep 23, 2003 07:36 AM
