Timing overghaul KA24DE
Old Nov 27, 2004 | 04:33 PM
two40's Avatar
I dont have the Sr20det yet, so i'll stick with the ka24de for a while.
But i need to do the timing chain on the KA.
Any recomendations, tips, etc?
Thanks.
Old Dec 1, 2004 | 12:16 AM
devnull's Avatar
A factory service manual is worth it's weight in gold.
Don't forget to set #1 piston to TDC on compression stroke *before* you remove the crank pulley and the front cover.
Bag and label every bolt you pull out. Bolts from same component should go in the same bag. Sealable sandwich bags + sharpie = stress relieving organization.
I'll know more quite soon, as I'm in the middle of doing one. My engine is on an engine stand however, with both manifolds off already. The FSM says that it is necessary to remove the head, so order a head gasket when you order your timing set. Also you should take the opportunity to replace some of the less accessible rubber hoses while you're at it.
Old Dec 1, 2004 | 12:49 AM
LTSCUDRFT's Avatar
Re: Timing overghaul KA24DE
Thanks.
Search, it's been covered more times than necessary. Because PEOPLE don't SEARCH before posting.
93slicktoptt
May 12, 2009 02:10 PM
djsilver
Jul 13, 2008 02:49 AM
ofl0926
Jun 3, 2005 08:24 PM
jdmwhites13
Dec 9, 2004 11:30 AM
strat13
Sep 12, 2002 10:10 PM
