Vacuum Diagram for 1990 SOHC
Old Apr 3, 2007 | 10:34 AM
BADA$$240's Avatar
Man guys I need a vacuum diagram bad bc I got some vacuum leaks and I can't find em so I need a diagram to check to make sure all the hoses are going to where they're supposed to so I was wondering if any of ya'll knew where I could find one bc there's not one in my Chiltons?
Old Apr 3, 2007 | 01:16 PM
BADA$$240's Avatar
Alright I got it to idle but now the whole engine and car is shaking like really bad when its idling and I have massive power loss so I'm guessing more vacuum leaks? And also I have a coolant lead somewhere like on the backside of the head but I can't find a coolant hose back there? I need some help guys so anything would be greatly appreciated.
Old Apr 3, 2007 | 03:26 PM
a vacuum leak is not going to make your car shake, ill see what i can gather from my notes... sorry i didn't see this post
the coolant lines on the rear are the feed and return of the heater system
Old Apr 3, 2007 | 04:41 PM
BADA$$240's Avatar
Could the timing being off be the reason why the car shakes when on idle? I know that there's a penny sized hole in the back of my header from the EGR pipe not being in there anymore but the nut is, could that have anything to do with it?
Old Apr 3, 2007 | 06:28 PM
BADA$$240's Avatar
Man thanks for your help but I think the block is cracked. Water is pouring out of the the exhaust and EGR piping hole in the header, I timed the engine and saw no improvement and it can't be a cracked head or head gasket bc they're both new and checked out. So my only guess is that there's a crack in one of the cylinder walls or in the block somewhere else, man I just wasted $500 rebuilding the engine to get to this, I'm pissed. If you could direct me to a good block to buy though I would appreciate it.
loc_staa05
Jan 12, 2007 03:16 AM
D0Ri-CHaN
Jun 7, 2006 07:58 PM
s13_peacekeeper
Apr 3, 2005 01:36 AM
NcTwOfOuRtY
Jan 24, 2004 06:15 PM
nismo180sx
Sep 26, 2002 07:16 PM
