werid a/c problem
Old May 10, 2005 | 08:19 PM
portion's Avatar
werid a/c problem
hello i have a 92 240sx Dohc 5 spd
car works fine but when i drive wit my a/c on, the gears become very notchy to a point they do not go into gear anymore. The clutch seems to be engaged somehow even though i mash the clutch all the way in when this happens.
When i take off the a/c and shut off the car for about 20 mins the gears works fine.
i am thinking its something wit the a/c being on it heats up the transmission or something like that.
i am not sure
i was kina told it could be the clutch cylinder or something that if it get to hot?????
can anyone help me with this problem? these days its soo dam hott i need a/c
Old May 11, 2005 | 08:23 AM
dkdeleon's Avatar
its not your a/c
Old May 11, 2005 | 01:14 PM
portion's Avatar
i really dont know
but it only happens when i run the A/C
Old May 11, 2005 | 03:57 PM
ProjectMy240's Avatar
don't know never herd of that before..
Old May 12, 2005 | 08:02 PM
Joel SX's Avatar
maybe it has a voodoo. Get an exorcisim done to it.
Or take it to your local spiritualist (mechanic).
Sometimes I see some things that are so wierd, yet related to each other it makes me think what is actually happening in some poeple's cars.
Old May 15, 2005 | 10:44 AM
Your A/C isn't connected to your transmission. Like said above, it's not your a/c.
Change gear oil. Try that first.
Old May 19, 2005 | 11:59 AM
Texas240's Avatar
probably has something to do w/ the extra load on the engine?
I've got an 89 auto and the engine runs like a$$ when i have the a/c on (not to mension i keep on losing a/c control heads for some unkown reason).
geez i hate early airconditioners
Old May 22, 2005 | 11:37 PM
thing is, the a/c compressor runs off a belt to the crank - not the transmission itself. I'd understand if "when I turn the a/c on the car idles low" or something that would be related to load on the crank, but the original poster said something about his tranny gears getting notchy. That's where it doesn't make sense to me, because no matter how you look at the a/c compressor, it's a far reach to affecting the feel of the gearshifts.
BTW long time no see homegirl
Old May 23, 2005 | 04:25 PM
LA_phantom_240's Avatar
maybe he has bad synchros and only notices it when he has the a/c on... the mind has a way of fooling itself like that. Anyway, like its been said before on here, change you gear oil, then see what its like. Other than that youre SOL in the department of advice
Old May 23, 2005 | 04:41 PM
portion's Avatar
yea i will give it ah try
thx for the replys
Old May 23, 2005 | 05:18 PM
Texas240's Avatar
^.^ whassup l2aine. I be back from a bad semester. woo.. i've now officially been tuning for a year!
Old May 23, 2005 | 05:49 PM
thx for the replys
Thats what we're here for isnt it?... or maybe its cuz we're all bored and dont have a life... um... well in any case... uh.. i forgot where this is going so... um... yyyyeah
WOOT for short attention spans!!!
Old May 24, 2005 | 06:42 PM
Texas240's Avatar
Ah ha!!!
the a/c IS connected to something called the fast idle control switch. i think that's what is fubaring the engine, and making the trans feel like it's going.
Old May 24, 2005 | 07:01 PM
k... test it. if it works tell us
Old May 24, 2005 | 07:43 PM
Ah ha!!!
confirmed... but I still can't imagine how that would change the feel of the shifting
