What the hell!!
Old Feb 22, 2006 | 06:21 PM
zenkislider's Avatar
stupid suggestion but could it be the TPS(throttle position sensor)? just sumthing that cam to my mind.
Old Feb 22, 2006 | 06:34 PM
LA_phantom_240's Avatar
Uh... i dont know if anyone suggested it, but your problem will most likely be a starter on its last legs. If you have a new battery, oil and everything, then the starter should spin the motor fine right? (nod your head) What is happening is the starter cannot spin the motor fast enough because the engine's compression creates a lot of resistance on the starter, and if its weak and on its last legs, itll lag. Believe me, this is not all that uncommon.
Old Feb 23, 2006 | 01:32 AM
dkdeleon's Avatar
did you check the valves when you had the head off?
when your trying to start it does it turn normal(lopeing sound)
or is it constant turning(without lopeing sound)?
Old Feb 23, 2006 | 01:12 PM
Slidin240's Avatar
its not the valves, i took the head to a shop to get tested and everythings fine
when the weather gets better ill check out all the connections again
Old Feb 26, 2006 | 07:35 PM
LITTLEDEVIL S13's Avatar
check timing def.. check fuel "pressure", air ,and the tps signal he might have somthing there cause if the ecu sees 5 volts of reference then the ecu thinks the tps is a wide open throttle and might cause the injectors to not fire... soo like you said check everything, i would also suggest ecu codes and see if u can hear the injectors firing..... PEACE
Old Jun 21, 2009 | 11:34 AM
brodie300's Avatar
what is meant by timming could be 180 off and what is the proper way to fix it? I am having the same problem spark fuel it turns but will not start! Car has been dead for 2 weeks!
Old Jun 21, 2009 | 04:17 PM
JapanS15's Avatar
Have you checked fuses? I know when I installed my turbo in my RSX that I used to have, before I started it for the first time...the install manual said to pull some ignition or something similar fuse so that the engine would turn over sending oil in through the turbo before actually starting the car. Then it said to reinsert the fuse and start it up. I know this may be a shot in the dark, but shouldn't take but 5 minutes to check them
Old Jun 23, 2009 | 09:34 PM
BigVinnie's Avatar
Please don't post in old threads that no one is a member of any more, please check the dates of when that member last posted so that you don't need to post.
Thread Closed.
leiferik1
Midwest
Dec 16, 2002 12:47 PM
Silviaspeed
Nov 7, 2002 06:36 PM
leiferik1
Oct 31, 2002 11:13 PM
leiferik1
Sep 27, 2002 03:01 PM
leiferik1
Aug 27, 2002 11:08 PM
