when you install your intake, where do you put the intake temperature sensor
Old Jul 21, 2004 | 06:08 PM
PissonH's Avatar
where to put the intake temperature sensor that was in the oem air filter box, since im going to have an exhaust like the injen one, i want to know where to put it because obviously on wont be able to bolt it, like it was bolted on the box, since it will be a cone filter...
thankx
Old Jul 21, 2004 | 06:31 PM
ryan15's Avatar
unplug the *****, if it throws codes tell me and I can tell you hwat kind resistor to put in there cuz I dont know if OBD II is different.
Old Jul 21, 2004 | 06:37 PM
PissonH's Avatar
so basically your saying it doesnt make a difference if its plugged or unplugged, it wont hurt the engine...
Old Jul 21, 2004 | 09:36 PM
JeromeS13's Avatar
Re: when you install your intake, where do you put the intake temperature sensor
thankx
Since when does any S chassis car have an IAT sensor on the exhaust
Old Jul 22, 2004 | 09:06 AM
NcTwOfOuRtY's Avatar
on a 90 ka24e could u just remove that to?
Old Jul 23, 2004 | 03:34 AM
I think he meant intake guys... give him a break
As for the question, if you buy a REAL Injen, there's a spot on the adaptor where it'll screw right in, no worries. If you buy an Ebay intake, chances are 50/50... some of them have a hole in the MAFS adaptor that you can screw the IAT sensor in, just like the Injen, but some don't give you anything, so either you shove the sensor inside the cone filter and tighten the folter clamp over the wire (really dumb idea) or you put one of those "+20HP WOWOWOW" resistor jobs on Ebay that keeps you fuel mixture at WOT, even if your car is idling (also a bad idea)
Old Jul 23, 2004 | 06:32 PM
PissonH's Avatar
so basically , im ****@#$#$
Old Jul 23, 2004 | 07:03 PM
why, did you buy some no-namer brand?
Old Jul 27, 2004 | 08:03 AM
PissonH's Avatar
i bought the bomz intake, i think 200 + dollars for an intake is bs....
Old Jul 27, 2004 | 08:18 PM
Guitarded's Avatar
drill holes for it and put a little elbow grease into it. It's not that big of a deal and then you won't have to worry about your ecu "throwing codes"
Old Jul 28, 2004 | 08:03 PM
PissonH's Avatar
sounds good
thanks
Old Jul 31, 2004 | 07:56 AM
It shouldn't be too hard - you don't have to worry about threading anything since the IAT screws thread into a small metal plate anyways... just don't forget to use a drop of threadlock for the screws... you don't want that little plate falling off
Old Aug 8, 2004 | 09:19 PM
Djrockz415's Avatar
i just unplugged it and left it alone on my 89 s13..no codes or anything..but my idle jumps sometimes and the guy i bought the car off of told me it was cause of the IAT being unplugged...when i put the stock airbox in the idles stop jumping..i could be wrong ..iono or my car is just ****ed up
Old Aug 25, 2004 | 07:46 PM
TekRPS13's Avatar
well i left it unplugged and nuthign has happened so far but then again ive only had it for 2 days
Old Aug 25, 2004 | 10:32 PM
well it is there for a reason. But whatever floats your boat
