Where is the egr valve located?
Old Mar 16, 2004 | 09:40 PM
tallic_red240sx's Avatar
The reason im asking is because i want to clean it.I mtrying to diagnose a acceleration problem,I already removed the AIV and it helped a bit.......
Old Mar 16, 2004 | 11:44 PM
LTSCUDRFT's Avatar
it's behind the intake manifold with a pipe that travels to the header.
Old Mar 18, 2004 | 12:23 AM
...'s Avatar
it shouldn't create an acceleration problem, but it's on the passanger side at the back on a '92, not sure about a 91 though.
Old Mar 24, 2004 | 07:11 AM
ZenkiSE's Avatar
From: You know the dirty south...I live in the clean spot
what are the advantages of removing the AIV and the EGR?
Old Mar 24, 2004 | 08:41 PM
JeromeS13's Avatar
A cleaner looking engine bay.......
Old Mar 26, 2004 | 07:46 PM
sleighty's Avatar
i am haveing a surging prob with my 240sx and i removed the aiv and it helped a bit also but it didn't clear it up. next i will be trying the tps and the o2 sensor. also i have heard others talk about a knock sensor but i am not sure on how or whom besides the dealer could go about diong this one.... if you guys find a solution then please let me know....
Old Mar 26, 2004 | 07:52 PM
JeromeS13's Avatar
Does it mainly do it at idle? And surge between 500-1000rpm? If so, check all of your vacuum lines, mainly the one big on under your upper plenums (goes to the IACV, IIRC).
osal1989
Mar 17, 2008 07:03 PM
Michael.Timz
Aug 29, 2007 08:12 PM
rpgfan
Feb 13, 2006 02:20 PM
Wish_itwasJDM
Jan 4, 2005 07:22 PM
brooksmosher
Jan 13, 2004 11:23 AM
