will this fit??
if i were to obtain the A/C compenents from a 91 240 (compressor condenser etc) would they fit right on my 95?? thanks for the help guys
nebody got an answer to this??
in theory they should, same engine. A friend of mine has a 91 fastback and dropped a 95de head and block into it and he said that everything bolted up just fine.
thanks for the response... if anyone else has info for me please let me know. thanks guys.
no it wont work they changed the mount
is there any way to make it work?? It's the same block right, couldn't I just use his the mount from the 91 and bolt it onto mine, or is it a lot more complicated then that?
does anyone else know nething about this??
just make your own mount. it'll work
is that hard to do??
well, if you have a machine shop in hand, then no, its not. But guessing you don't, then its really hard to do a mount like that, because it can't be all crapy and soft. It has to be very strong, I recomend you buy that piece new, and then drop what ever u were going to drop.
Get the mount off of the 91 & 95 ...experiment.
If the compressors are the same( call the stealership & find out) & just the mount is different. One of them should work. |
ok thanks
