will this fit??
Old Oct 13, 2004 | 05:36 PM
idrvsideways's Avatar
will this fit??
if i were to obtain the A/C compenents from a 91 240 (compressor condenser etc) would they fit right on my 95?? thanks for the help guys
Old Oct 14, 2004 | 05:40 PM
nebody got an answer to this??
Old Oct 14, 2004 | 09:23 PM
Next Level 240's Avatar
in theory they should, same engine. A friend of mine has a 91 fastback and dropped a 95de head and block into it and he said that everything bolted up just fine.
Old Oct 15, 2004 | 03:58 AM
thanks for the response... if anyone else has info for me please let me know. thanks guys.
Old Oct 15, 2004 | 04:07 PM
juggalo_240's Avatar
no it wont work they changed the mount
Old Oct 15, 2004 | 05:04 PM
is there any way to make it work?? It's the same block right, couldn't I just use his the mount from the 91 and bolt it onto mine, or is it a lot more complicated then that?
Old Oct 16, 2004 | 06:19 PM
Old Oct 17, 2004 | 06:51 PM
does anyone else know nething about this??
Old Oct 17, 2004 | 10:08 PM
toycar49's Avatar
just make your own mount. it'll work
Old Oct 18, 2004 | 03:42 AM
is that hard to do??
Old Oct 18, 2004 | 09:19 AM
Joel SX's Avatar
well, if you have a machine shop in hand, then no, its not. But guessing you don't, then its really hard to do a mount like that, because it can't be all crapy and soft. It has to be very strong, I recomend you buy that piece new, and then drop what ever u were going to drop.
Old Oct 18, 2004 | 09:52 AM
Project Cheap13's Avatar
Get the mount off of the 91 & 95 ...experiment.
If the compressors are the same( call the stealership & find out) & just the mount is different. One of them should work.
Old Oct 18, 2004 | 11:08 AM
ok thanks
BobTheSlob
Sep 26, 2002 09:28 PM
rbboyl
Sep 21, 2002 02:23 AM
rudeboy
Sep 20, 2002 04:31 PM
trickedout
Jun 15, 2002 05:57 PM
Condom_Sense
Mar 12, 2002 07:55 AM
