wont start..
k,s14 5 speed swapped into an s13. ka24de of course.
uh, wont start at all. i turn the key and nothing. |
check under fuse box in engine bay... you will see a connector, cut the wires and wire them to each other this will allow the car to crank.
did that already.
well if you did that and followed every step to install the swap... it should fire.. check all your steps bro.
well i also swapped motors too...
AHHHHH now the plot thickens lol
when you turn key are you hearing the fuel pump and injectors click? well first are you getting any power? |
yes i have power i guess, cause my radio works and what not..i dont hear the fuel pump though..what do the injectors sound like? when i turn the key, its just a quick click thats it..
well to hear that click you must be out in the bay.. but you should hear the fuel pump prime.
however if your turning the key and you are getting no cranking, check your starter and your fuses make sure all of your grounds are secure mainly the ground on the intake manifold. |
which ground on the intake? My batterys in the trunk if that helps.
see this is hard man.. you did way to much at one time.... for your first time doing it.
there is a big black with yellow or red stripe wire that should be going from the chassis ( right under where the battery use to be ) to the intake manifold right to the left and down of the throttle body. how did you run the battery relocation. |
I found my problem! my starter isn't getting anything from the ignition, nor is the fuel pump..I got the motor to turn over, just gotta get the fuel pump sitiuated.
AHHHH you check the fuses??? also what gauge wire did you use for the batter relocation?
i bought legit ass wire..video of it running in my thread.
