Picture of the Day
those rims are off the 35th anniversary Z. I like those rims, I was thinking bout buying me a set and painting them or powder coating them. I knew it had to be someone with an s14 that would sport those
This car has EIGHT TIMES the amount of horsepower I have in mine. Redonculous.
2002 model
1800 km
1200bhp @ 2.6 bar boost
HKS racing 2.8L high deck complete engine, 1 of only 2 in existance
HKS head system STEP Pro V lifter, HKS STEP Pro IN/EX 296deg
HKS STEP Pro valve springs
HKS STEP Pro V valve IN set
HKS STEP Pro V valve EX set
Valve step seal set
Fully machined and modified head system
HKS GT3540 twin turbo
HKS special racing wastegate
Custom stainless wastagate outlet pipe
HKS metal head gasket
HKS oil pump
ATI crank dumper pulley kit
HKS GT intercooler cooler twin entry type
HKS oil cooler kit
TOP SECRET GT intake plenum
NISMO engine mounts
AUTO SELECT oil sump
Custom titanium exhaust
720cc main injectors X 6 + 440cc extra injectors X 6
Twin injector adaptor
BOSCH external fuel pump X 2 + SARD intank fuel pump
Custom collector tank
EARL'S braided fuel line
HKS fuel rail
HKS fuel regulator
Aluminium triple layered radiator
BILLION swirl pod set
SAMCO radiator hoses
BILLION electric fan X 2
OHLINS adjustable suspensions
S&S ENGINEERING pillow ball front arms
AUTO SELECT suspension arm pillow ball kit
HKS triple plate clutch
NISMO diff mount
NISMO member bush
13 point roll cage
Seam welded shell
AUTO SELECT frame support bar
RECARO Pro Racer SP-G bucket seat (driver side)
RECARO SP-G (passenger side)
HKS F-con V-pro ver3.1
HKS ETC torque split controller
HKS A/F knock amp
HKS EVC Pro
HKS turbo timer
TOP SECRET front bunper
TOP SECRET front carbon under diffuser
NISMO GT carbon bonnet
TOP SECRET carbon GT wing
TOP SECRET limited edition 18inch rims (VOLK RACING LE37)
NISMO LED GT tail lights
2002 model
1800 km
Valve step seal set
HKS oil pump
HKS oil cooler kit
NISMO engine mounts
HKS fuel rail
HKS fuel regulator
NISMO diff mount
NISMO member bush
13 point roll cage
Seam welded shell
HKS A/F knock amp
HKS EVC Pro
HKS turbo timer
