Pivot headlight controller problem - need electrical know how people
From: I like to spend my time at the cheesecack house!!!!!!!!!!!!!!!!!!!!!!!!!!1!!
hey yall, dont mean to intrude, and i hope this is not going to be considered the wrong section to post this is, but i have a miata, and have a problem with my pivot controller, and since alot of 240 people have one, maybe yall can help me.
if anyone needs it to understand what im talking about, here are the english instructions
http://www.3sxperformance.com/instal...ish-pivrhu.pdf
each car is hooked up diffrently, i know yall hook up the fuse wire to your ignition, well for me, i hook the fuse wire up to the gray wire. just to start this out, it works fine, i have no problems with it not working. all wires were hooked up to the appropriate place, and i assume if i had loose connections, it wouldint work. the only "loose connection" i can think of is, we used these type of screw connectors for the splicing, instead of the clamp type
so far people have told me my problem is:
-loost connections
-voltage surge
-faulty control box
Ok, heres the problem: sometimes the headlights fall down to a possition i did not want them set at. i have 3 ways to pop up my headlights. 1- turn them on, 2 - flash someone 3- push the button to pop them up.
2 makes them return to stock. all the time, and that seems like a normal thing, i guess.
3 seems as though it makes them return to a lower possition
1 is the biggest problem. lets say i park after driving at night, the headlights sometimes return to something higher, or lower then what i want, and turning on my headlights a couple of times in a row bring out diffrent things. this doesint happen all the time, just a couple. playing with it a few times will bring it back to the setting i want(if it matters i use setting 40%)
also, 30% and under does not seem to work, it juse returns to stock. now and then it might work, and pop up a little bit, but most of the time no.
so does this sound like a faulty box controller, or a power surge? and if its a surge, how do i fix it to be a constant voltage?
-loost connections
-voltage surge
-faulty control box
Biggamehit
Sep 5, 2011 08:10 PM
box, contriller, controller, english, headlight, headlights, instructions, miata, mx5, pdf, pivot, pop, popup, scrapp09com, troubleshoot
