what is this called?
Old Mar 29, 2008 | 11:29 PM
240driftfiend's Avatar
what is this part called that is broken??
Old Mar 30, 2008 | 02:47 AM
that part of the spindle hub assembly... what they hell you hit dude.
yea you need the entire hub assembly and looks like the Tie rod is bent to
Old Mar 30, 2008 | 03:08 AM
holy ****.
is the coilover mounting point and the tie rod mounting point both broken?
Old Mar 30, 2008 | 04:48 AM
yea man.. damn i just notice that also.. yea that tie rod is smashed i because its connected to the part of the assemble that broke off
also i hope the lower control arm is not broken also... damn dude.. tell us what happened
Old Mar 30, 2008 | 08:15 AM
This is the Firebird, right? I would check to see if the frame is bent too with all that carnage. That shock mount moved pretty far, the frame had to have moved with it.
Old Mar 30, 2008 | 12:55 PM
zenkislider's Avatar
isnt that called like the knuckle?
Old Mar 30, 2008 | 02:37 PM
you can see the whole story on check out my new f body thread
short story i had my wheels turned and smashed a curb
is it super bad??? i know nothing about suspension work
Old Mar 30, 2008 | 02:44 PM
yarou's Avatar
Um, holy ****.
Old Mar 30, 2008 | 04:13 PM
holy ****.
its just the part were the tie rod end connects to i think its called the spindle but not sure
Old Mar 30, 2008 | 04:17 PM
the lower control arm is fine and the frame is fine do you think if i just went to the junk yard and picked up the whole left front suspension parts i would be fine without any problems
ill take some more pics for you guys
Old Mar 30, 2008 | 04:42 PM
the only part thats f*cked is the piece i dont know the name of and the tie rod, the coilover mount and lower control arm is fine
EDIT: new rotors all the way around is coming soon
Old Mar 30, 2008 | 08:48 PM
That strut is cashed too dude, from all the pictures I have looked at that mount should not be bent like that. Is the other side like that?
Old Mar 30, 2008 | 10:39 PM
ill jack up the other side tomorrow and look
Old Mar 30, 2008 | 10:47 PM
wait are you talking about this
