what is this called?
Old Mar 30, 2008 | 11:49 PM
oh okay nvm.
i thought it was a 240 when i saw the first post.
other things may not be visibly tweaked but id be surprised if nothing else was bent.
Old Mar 31, 2008 | 12:47 AM
hahhah i thought it was a 240 also im like why cant i focus on this.. something is wrong..
and yes its a spindal hub assembly.. the hub is attaches to it... also it sucks to have the upper control arm in the mix.. thats probably bent also
Old Mar 31, 2008 | 12:08 PM
240driftfiend's Avatar
damn do you think i should try to mess with it or do you think it would just be a big hassle
Old Mar 31, 2008 | 12:53 PM
Project Cheap13's Avatar
The inner tierod is gone also..quite bent.
Parts you will need from the pics
Left hand spindle assembly( they come without the hub, you may need that also... TIMKEN Part # 513090 )
Outer tierod (MOOG ES3238RL)
Inner tierod (MOOG EV260)
As for the spindle. I do not have a part number.
Rockauto.com should have everything you need to fix it at great prices.
Old Mar 31, 2008 | 01:45 PM
thanks alot for that site, however i cant find inner and outer tie rods just tie rod ends
i think im lookin at about $400-500 in parts if i do the work myself, is that stuff pretty simple to install? if not i think im just going to try an sell or trade it because im not going to pay another couple hundred for labor the car isnt worth it .....thank you all for your help
Old Mar 31, 2008 | 02:06 PM
very easy fix bro...
standard tools man.. just visually look at everything take it off and put it right back the same way.. for the tie rod.. leave the old tie end on. mark the current position and use that as a reference point to get it as close as possible. its important because your wheel will be Toed in or out and different from the other side if its not exact.
as far as the parts, just search, they are available. tie rods and ends are standard parts nothing special about them.. check www.thepartsbin.com
or you local advance auto, auto zone or junk yard.
easy fix man... just download a FSM to help you along if you need help.
Old Mar 31, 2008 | 02:36 PM
thanks man
lrb_2000
Nov 16, 2004 06:05 PM
BrettWellicome
Feb 2, 2004 08:19 AM
tegg_gsr
Nov 21, 2003 07:36 PM
240SXpimp
Jul 29, 2003 11:30 AM
Damicci
Apr 16, 2003 09:03 AM
