TT and BC?!?!?
which one is more important you ask.......... Turbo Timer
hot oil will cook your seals and lower the life of your turbo
BC is not a necessity and is something that should be added only when your mods support it............. meaning just because you can turn up the boost, doesn't mean it suppose to be at the level.
raising the boost depends on fuel/air availability and range of the turbo itself
example
stock s13 sr20 (T25 turbo)
the range is about 15psi over stock ( 7-8 psi) anything beyond that turns your t25 into a "Hair Dryer" and will get you to the land of Detonation very very quick
example
crouton
Aug 24, 2004 09:32 AM
