Rb20det????
Old Apr 12, 2008 | 04:16 PM
slidinRB's Avatar
Rb20det????
I just got an rb20det for my 93' 240sx.im on a budget and im trying to just get the engine runing in the car so i can use it as my daily driver.its going to be set up for drifting.what are some hints as to wich parts i should replace/upgrade while i have the motor out?ive already replaced the water pump, tensione&idler, and put a greddy timing belt on it.any help would be great....
Old Apr 12, 2008 | 05:10 PM
HKST04Z's Avatar
replace the cam seals and clutch and since its a dd id suggest doing ur heater hoses as well. other than that u have pretty much everything else done that u need
Old Apr 12, 2008 | 05:24 PM
slidinRB's Avatar
ok..thanks man.what maf should i run??ik that the stock one is pretty much maxed out already..
Old Apr 12, 2008 | 08:11 PM
crazydrifter's Avatar
n60(maxiam) or n62(300zx) i think
Old Apr 12, 2008 | 08:51 PM
HKST04Z's Avatar
z32 will work, and rewiring it is simple
Old Apr 13, 2008 | 05:40 AM
the stock one is a N60...............
Old Apr 13, 2008 | 09:19 AM
slidinRB's Avatar
ok, thanks..now i just have to go find one..and another question..where do you have your BOV at?im either goin with the HKS SSQV or the GREDDY TYPE RS..im just trying to see where is the best place is for it..thanks again!
Old Apr 15, 2008 | 08:44 PM
Urban Outlaw's Avatar
How is the stock on already maxing out? I'd go ahead and replace all the gaskets as well. The BOV is on the charge pipe right above the head. And if u get a new one. make sure hook it back into the motor or when u let off the gas it'll die.
Old Apr 16, 2008 | 04:36 PM
slidinRB's Avatar
will i have to get an addapter for the hks or greddy, or will one of them bolt directly up?
Old Apr 16, 2008 | 08:38 PM
............ look at them. lol Which one has a flange?
Old Apr 20, 2008 | 06:11 AM
slidinRB's Avatar
the Greddy has a flange.....but i wasnt sure if that would fit the stock flange.
Old Apr 20, 2008 | 10:20 PM
Yellow4g63's Avatar
Talk to CarlH he live in SC, he can tune the ECU for some more power. He is on Nico and 240sxforums.
NightXCZ77
Nov 6, 2009 10:08 AM
Driftin180SX
Jan 23, 2005 12:19 AM
kaos
Jan 19, 2003 12:16 AM
NightXCZ77
21
Jan 17, 2003 11:32 PM
keithtau
Dec 15, 2002 02:33 AM
