gears for 240sx
does any one know wear i could get a cheap set of 3.90 ratio rear gears for the 240sx. The reason i ask is I race a 240 but i need different gearing to make the right rpm. Ive gotten as close as i can in the trans but need different rear gearing
How are you racing and what are you looking to get? I am only asking because I am curious to what gear changes can do for me as well.
Hi I race an 89 nissan 240sx in a local mini stock class at my home tracks. I need a 3.90 ratio ring and pinion gear set so that i turn less rpm and mainain the same speed. The only thing this hurts is your acceleration and in oval track racing you dont need a lot of acceleration if you can make your car handle and keep the r's up in the corners.
Originally posted by racecardriver66 Hi I race an 89 nissan 240sx in a local mini stock class at my home tracks. I need a 3.90 ratio ring and pinion gear set so that i turn less rpm and mainain the same speed. The only thing this hurts is your acceleration and in oval track racing you dont need a lot of acceleration if you can make your car handle and keep the r's up in the corners. You have to post up some pictures of that beast or at least email them to me at stanbo@speakeasy.org. I will look around for you and assign this task to my old school guy Angel. |
i did a lil search and every site i came by seems to stop selling a 3.90 R&P set:confused:
Originally posted by -HyJynX- i did a lil search and every site i came by seems to stop selling a 3.90 R&P set:confused: I would call Balanced Performance. They work on some 240s in the Nasport Racing series. Tell them StanBo sent you. When they ask what is a StanBo, you have broken the ice and will get the parts for cheaper. Trust me ;) |
Originally posted by StanBo They don't have to be new. As long as they are in good condition. I would call Balanced Performance. They work on some 240s in the Nasport Racing series. Tell them StanBo sent you. When they ask what is a StanBo, you have broken the ice and will get the parts for cheaper. Trust me ;) |
1 Attachment(s)
i have a brand new 3.917 R&P Set in a box.
make offer |
