Road Race/AutoX If you like road racing, autoxing, or track events, then this is the spot for you.
is ground control suspension worth it?
Old Oct 23, 2007 | 01:49 PM
driftfreek's Avatar
i heard about ground control suspension and it sounds pretty cool, the problem is that i couldnt find out the springs rates, how stiff could one go with GC? any info...?
Old Oct 23, 2007 | 02:00 PM
HPF Chrisk's Avatar
They are just springs and perches and you have to run like kybs or struts, go with a set of full coil over, kts, hks, greddy, stance, ect.
Old Oct 23, 2007 | 11:14 PM
I believe you can get custom spring rates with ground control. Pair them with something like Koni Yellows and you'll have a nice setup.
Old Nov 16, 2007 | 07:49 AM
CharlesJ's Avatar
Club240 Staff
Ground control is all in how you use it. They have many different options and totally custom on rates. Pair it with a nice damper like the koni yellow mentioned above and you have a make it yourself coilover it. For my first modified car, I had an old prelude back when there were no available coilovers. I got a set of koni yellows and custom ground controls. The sleeve fit tight around the strut body making it look no different than a coilover package. The handling for exceeded other setups I used on that car. The downside is because they are not made for each other, he stroke, vs spring length is not right and really needed a helper spring. When I went of rises, the spring would go loose and jingle around.
So they are not bad, but really best used on cars that have no package options available. I do however like the idea of koni yellows and some nice standard springs though a little more for this car. The koni's have something like a 4 position adjustable perch on them, so you can adjust height with them even on a fixed spring
Old Nov 16, 2007 | 08:59 AM
Kind of pointless unless the price savings is substantial.
You can get a Full True coilover set-up for a reasonable price.
I think its much more worth it
Old Nov 18, 2007 | 05:04 PM
slos14's Avatar
they do ? i have them on my car an i never new they had that . i love them koni yellows are a nice set up . for a d/d
Old Nov 19, 2007 | 06:56 AM
nissandrift's Avatar
From what I gather the Koni's can be rebuilt for whatever spring rate you want, and will end up having a much better damping rate than off the shelf coilovers that dont offer bound/rebound adjustability. With that said I have Stance on my car, and Im happy... but the thought has crossed my mind to eventually do a GC/koni setup.
Old Nov 19, 2007 | 07:00 AM
CharlesJ's Avatar
Club240 Staff
That is a good point. If you want coilovers that can be revalved for custom spring rates, you need to go with JIC A2s, KWs, or higher. Many coilovers offer a selection of spring rates, but fail to match the damper with the new rate. Mismatching damper valving with spring rates is a sure way to get crappy handling.
TRexRacer
Mar 15, 2009 04:59 AM
NismoKid26
May 25, 2004 09:32 PM
2sick240
16
Nov 27, 2003 11:36 PM
FSPtwo4d
Group Buy / Specials Classifieds
Dec 30, 2002 05:59 AM
DeFcOnS14
Feb 23, 2002 12:26 PM
