Road Race/AutoX If you like road racing, autoxing, or track events, then this is the spot for you.
set up for racing in stock form
Old Feb 27, 2004 | 10:54 AM
1995 240sx's Avatar
I have a stock 240 and was woundering about how to go about having the car ready for a weekend at the stip or at an autocross event.
for the strip should i take all the wight i can out of it or should i leave some in the tunk for traction?
should i lower the PSI in the rear tires for a little better launch?
How much gas should i run in the tank?
for an autocrss event the same questions
is the lack of waight in the rear going to throw off the wight balence or should i add a little to the rear and try and take some off the front to get closer to a 50/50 split?
if anyone has any other tips to that you know of to help the car handle a little better in it stock form would be most helpfull
Old Feb 27, 2004 | 12:43 PM
mr_synister's Avatar
for drag, certainly lower rear tire PSI, about 20. Since it's RWD you shouldn't need weight in the rear cause it's all gonna shift that way anyways. It's good to have as little gas as possible to get there, race, and get home. Less weight. In AutoX you should do what makes you comfortable. Weight in the rear could cause oversteer, but you may like a little OS. I think 240 are already one of the best balanced cars out there F55%/R45%. I think that you'll get better handling cutting as much weight as possible. I'm not a pro but this is what I do when I go to the track. Hope it helps!!!
Old Feb 28, 2004 | 01:58 AM
Catharsis's Avatar
if you stip for autoX get ready to have you *** handed to you beacue you bumped your self into a higher class
Old Feb 28, 2004 | 10:52 AM
He's talking about "a weekend at the stip or at an autocross event". I'm sure he's not in a competion. Less weight will make you handle better, but in turn will put you in a tougher class. If your going out for yourself and to just have a good time, strip it.
Old Mar 1, 2004 | 10:04 AM
1995 240sx's Avatar
looking just to beat friends times at the same event dont really care what classs i am in
what do yall suggest to stip it of all the wight i can?
spare tire /jack
floor mats
tash & other junk in car
empty warsher fluid
Still want it too look unstrip if you look in the windows so will leave the seats and panals in
Old Mar 1, 2004 | 01:45 PM
I think the floor mats will be ok. hehe. I'd just clean the trash for looks and lose the spare.
DUFFM4N
Oct 9, 2006 11:59 AM
weei2
Feb 11, 2005 05:05 PM
NSNPWR
Jul 15, 2004 07:41 PM
S13 Slide
Apr 3, 2004 12:00 AM
