Just got one
Old Feb 18, 2008 | 04:30 PM
Slick-240's Avatar
Just got one
Hey i just got a 1990 240, the guy i baught it from said it blew the head gasket and started spitting coolant out the tail pipe. Any one know what i need to do to start fixing this problem?
Old Feb 18, 2008 | 05:07 PM
240driftfiend's Avatar
welcome to the forum ..pics?
Old Feb 18, 2008 | 05:09 PM
you need to take the head off and replace the gasket. but once the head is off it would be a good time to inspect the valves and replace them if needed or get a valve job if needed also. it would be good if you knew what caused the gasket to fail in the first place so you could have a better idea of what needs to be replaced.
Old Feb 18, 2008 | 05:11 PM
Slick-240's Avatar
Thanks for the welcome, I should have pics up soon, I believe the cause of the gasket blowing was the fact that it kept overheating...possably the thermostat. thanks for the info.
Old Feb 18, 2008 | 05:48 PM
Slick-240's Avatar
Im gonna stick with my KA. I heard its a stronger block than the aluminum sr... not sure but i dont feel like trying to source out an sr so if some one could point me in the directing of a good turbo for KA's i would be much appreciative.
Old Feb 18, 2008 | 09:35 PM
TypeX180's Avatar
SR's are almost falling from trees...they are SOOOO common...
anyway, welcome dude..lets see the car
Old Feb 18, 2008 | 09:45 PM
Welcome
Old Feb 18, 2008 | 10:31 PM
If you search theres boatloads of info on the KA-T, arm yourself with knowledge! Welcome man.
Old Feb 19, 2008 | 03:50 PM
94Boy's Avatar
Hey man welcome. I would help you out but I do not know much so. So welcome here
Old Feb 19, 2008 | 03:54 PM
DarkPhoenix's Avatar
Welcome!!
When you do the headgasket, if you do it, have the head checked at the machine shop. Overheating it could have warped it, which would have caused the gasket failure.
Old Feb 20, 2008 | 03:08 PM
Slick-240's Avatar
i think i found the true reason for the gasket failure. I found a big crack in the radiator wich lead to the loss of coolant wich caused the engine to overheat.
Old Feb 23, 2008 | 03:00 PM
Slick-240's Avatar
ok, so new plan. anyone have the ka engine left over from there enigine swap? I just discovered that my engine is siezed and now im in search for a new engine. If you have one let me know and we can set sumthin up. Thanks
Old Feb 23, 2008 | 05:55 PM
welcome man. i used to live in Jacksonville. moved in 04. Anyways good luck with your car. Prob wont find a KA here. might need to try a bigger forum. or possibly just rebuild yours.
josh240caseysx
Oct 6, 2006 02:30 PM
gfx
Jan 17, 2006 11:15 AM
BeDrift
Sep 8, 2003 10:44 PM
Yoshi
Mar 8, 2003 04:55 AM
98S14
Oct 9, 2002 05:20 PM
