silvia sr20det parts galore
Old Jul 31, 2008 | 01:32 PM
bs280's Avatar
Silvia oem fenders-175
Silvia dual projector headlights-175
Brand new z32 e-brake cable's-90
3 Sr20det coil packs-30
ka24de Motor with 98k-300
auto Tranny shifted perfect-150
ka wire Harness un-cut-70
ka24e Ecu-50
auto Driveshaft-25
s13 pignose front Bumper-80
s13 240sx hood-90
custom greddy intercooler-150
genuine GARRETT GT2876R gt25/40 off of my s13 sr20det. This turbo has a .70ar compressor housing with a 4inch inlet and a .64ar exhaust housing for faster spool. The exhaust housing has been ceramic coated and the wastegate flap is welded shut for the use of a external wastegate. Turbo was only boosted at 8psi on stock tial 8psi spring. This turbo also bolts to the stock sr20det exhaust manifold. It has no shaft play and spins freely. There is nothing wrong with this turbo everything on it is perfect. It has the garrett stamp on it with the turbo part number 705330-1. It makes full boost by 3700 and it can make over 400whp. It comes with a 4inch to 3inch coupler for a intake for the sr20det the turbo alone is 1300 new.-750firm
Compressor
-Wheel: 76mm w/ 48 trim
-Housing A/R: .70
Housing Type: 60-1 w/ 4" inlet & 2.5" Oulet
Turbine / Exhaust:
-Wheel: 53mm w/ 62 trim
-Housing A/R: .64
-Housing Type: T25
Center Section
- Dual Stainless Steel Ball Bearings
- Oil & Water lube/cooled
some pics- http://s89.photobucket.com/albums/k224/240slider/
weei2
Jul 21, 2005 08:13 PM
comnatusideways
Jul 6, 2005 08:08 PM
Heely
Apr 6, 2004 01:33 PM
Heely
Feb 18, 2004 07:40 PM
Heely
Dec 21, 2003 10:12 AM
