Tein Suspension Products- IN STOCK!
We have a bunch of Tein products in stock and ready to ship out
Tein Pillowball Tension Rods- S13 & S14 both in stock!
The rubber bush of the tension rod has been replaced with pillow ***** (spherical bearing) in all TEIN's Pillow Ball Tension Rod to eliminate tow change through compliance on acceleration or deceleration and allow only for vertical movement by the lower - arms. It also reduces the roll at corners and creates quicker steering response. In addition, the wheel alignment (caster angle) can be set through adjustments.
- Rod End & Pillow Boots- By adopting NMB's 3 piece rod end - HRT16E -, we have achieved outstanding endurance for the products. We have added protective boots for better weather resistance with the safety regulations.
- Tension Rod- Machine structured carbon steel - S45C - has been adopted for the material.
- Serration Bolt- High tension material SCM435 has been used for the bolt. As it is already pressed in the rod, installation time has been reduced.
- Pillow Collar- Machine structured carbon steel - S45C - has been adopted for the material with high anti - corrode nickel - plated.
- Lock Nut- There is 10mm adjustment width on the lock nut. The original setting is at the center, so adjustment can be made on the range of +/- 5mm (+/- 15mm for those with turn buckle).
Price: PM me!
Tein Tie Rods & Tie Rod Ends- IN STOCK!
- Strengthened Tie Rod- Improved durability and increased steering wheel cut off angle. This will allow for a higher steering angle at full steering wheel lock. All for a reasonable price.
- Superior Durability-Tein tie rods are designed to be stronger than original equipment found on the 240SX (S13 and S14). During hard sport driving, breaking and bending of the tie rods will now be reduced.
- Increased Steering Wheel Cut Off Angle- Tein tie rods are adjustable to give you more steering angle at full steering wheel lock. Original equipment tie rods offer limited steering wheel rotation, while Tein tie rods allow for increased rotation.
- Excellent Option For Drifting- Tein tie rods can be adjusted for more steering angle for when you counter steer. This will in turn create deeper drift angles.
Price: PM me!
Tein S-Tech Springs- Both S13 & S14 in stock!
S13 Front Drop: 1.5 inches
S13 Rear Drop: 1.2 inches
S14 Front Drop: 1.3 inches
S14 Rear Drop: 0.9 inches
Price: PM me!
Tein H-Tech Springs- Both S13 & S14 in stock!
S13 Front Drop: 0.9 inches
S13 Rear Drop: 0.6 inches
S14 Front Drop: 0.7 inches
S14 Rear Drop: 0.4 inches
Price: PM me!
Price: PM me!
Price: PM me!
For Sale - Wheels / Tires
Nov 2, 2007 08:09 PM
speedalliance
Nov 26, 2002 08:48 AM
