5 Lug Conversion
Old Dec 25, 2003 | 02:44 PM
rameek's Avatar
5 Lug Conversion
I was wondering has anyone here done a 5 lug conversion for their 240's. I was wondering also since i have a 90 240 would there be a limit to what years i could use for a 300 zx or newer 240's?
Any information like time, cost, problems would be helpful!
Old Dec 25, 2003 | 04:49 PM
Taken from the FAQ im writing..
Here is a list of what you will need to complete your 5 lug swap.
-S14 SE Hubs
-S14 SE Spindles
-S14 SE rotors (or any other 5 lug rotors that work properly on the 240)
-5 lug wheels
-New brake lines
-New cotter pins
-Wheel bearing grease
With all of that you will be set for the 5 lug swap, but at a pretty hefty price. This swap can cost you close to or over a grand for everything.
I havent done the conversion personally..just helping you out
Old Dec 25, 2003 | 05:30 PM
rameek's Avatar
I had no idea i read it in the november import racer magazine and they made it seem cheap basically just the purchase of the hubs and a day and it could be done. The hubs they say they got were about $50 a piece!
Thanks for the info!
Old Dec 25, 2003 | 05:35 PM
This is including all the other shi* you need to get, not just the spindles man. in the end its pretty expensive
Old Dec 25, 2003 | 06:05 PM
rameek's Avatar
Your right it looks expensive. So when are you going to finish your write up? I was thinking of using the 300zx rotors and callipers until i can afford the big rotor caliper conversion. Are the s14 rotors as big as the 300z? I was going to use the tires from which ever conversion i was going to get until i decide what rims i can get.
Old Dec 25, 2003 | 06:48 PM
Im almost done..just been a lil lazy and confused on how to do it. The Z32(300zx) calipers and rotors are bigger then the S14 brakes.
Old Dec 25, 2003 | 07:02 PM
rameek's Avatar
Will it have price break down as well or just whats needed and the necessary parts.......
Take your time because it will be my bible when i do the conversion do not leave out anything...
The s14 & z32 is roughly the same price to do the conversion?
Old Dec 25, 2003 | 07:19 PM
Id think the Z32 will probably be a lil more expensive..but im not exactly sure on that.
Old Dec 25, 2003 | 09:00 PM
SLIDE OR DIE's Avatar
Im getting my 5 lug convertion and Z rotors for $350 not including rims from a nissan salvage yard!
Old Dec 25, 2003 | 09:04 PM
irax's Avatar
at heavythrotle they have conversion sets starting at around 600 dollers, and go upto 899 for a full front and rear, slotted drilled brimbo roaters 300zx break calipurs and heavy metal breakpads, and they will drill the 5 lugg dics into 4 lugs so you dont have to do 5 lug conversion if your just doing it for better breaks, i think thats the best price i could find, PDM-Racing.com has the conversion for just the front set of breaks for 900 dollers.. so it just depends where you find the parts
Old Dec 26, 2003 | 09:48 PM
areitu's Avatar
pdm-racing.com also sells the conversion kit complete with new parts.
Old Jan 5, 2004 | 07:50 PM
boricuajr's Avatar
really expensive though!!
Old Jan 14, 2004 | 05:56 AM
E Spin's Avatar
the only advantage i've heard and read about the 5 lug conversion is just a wider choice for wheels. are there any other advantages from switching over to 5 lugs instead of keeping it 4?
Old Jan 14, 2004 | 10:05 AM
Uhmmm...you can upgrade to Z32/R32 brakes or whatever 5 lug brakes you want to. You can do that with 4 lug...but you have to re-drill holes
Old Jan 14, 2004 | 01:29 PM
rameek's Avatar
Its been difficult to find these hubs to do the conversion everyone wants to give me the whole spindal.......
Right now i found a guy that said he can get me the whole spindal for a buck a piece ($100 slang) for all 4 but i am not sure that i need the whole spindal though.
I am only doing this until i can afford (no time soon ) a big break conversion later...
The advantages for me is the diverse selection of rims and tires (which will be a set of advan TCII GTR design), z32 bigger breaks and calipurs than stock, secures better stopping, secures better wheel to car!
