A/C Compressor Problem
I have a 92 240sx and my a/c compressor died. I'm trying to buy a used compressor from someone I hooked up with that was parting out a motor. Problem is I'm not sure if it will fit. He has a 1990 model car and doesn't think the bracket will support the compressor on my block. Although I found on NissanPartsStore.com that Nissan used the same compressor from 1990-1993. Can anyone back this up about the bracket fitting the block and compressor? Thanks.
Wes
Wes
Here's the compressors from an SR, DOHC and SOHC in that order.
Basically you'll have to custom fabricate a bracket of some sort to get it to bolt on. I'd just get a DOHC compressor if I were you though. Save yourself the headache.
uvamosk
Aug 12, 2005 07:31 PM
totalled 96 se
Feb 29, 2004 01:16 PM
Topless240
Apr 23, 2003 07:05 PM
