HEY......awnser this for me.......please
Old Oct 7, 2002 | 09:38 PM
rudeboy's Avatar
is the R32 LSD an R200? seein that i didn't get my other S15 which would of worked for me i'll try the R32 LSD. any good opinions on this
Old Oct 8, 2002 | 06:13 AM
Import Fanatix's Avatar
Isn't the R32 4wd, therefore a different differential entirely?
Old Oct 8, 2002 | 09:57 AM
I'm with Stupid's Avatar
All the trims below GTR were RWD.
Old Oct 8, 2002 | 02:37 PM
SilvaPwr's Avatar
AWD LSD in a RWD?? Dont think it will happen....
Old Oct 8, 2002 | 03:38 PM
wouldn't a z32 rear end fit also with some adjustments?
Old Oct 8, 2002 | 05:01 PM
StanBo's Avatar
What would be the major difference between a rwd LSD and a AWD LSD????
I would think that the awd hardware is further up front. The option is RWD or AWD. The different hardware is furthur up the drivetrain.
I cannot see them making two totally different rear ends for an AWD.
We non HICAS guys can use the LSD from there. The only difference on the drivetrain was the rear HICAS member and accessories.
The rear driveshaft might be different in length but I can definently see it working.
I know the shifter is the same. The B&M is good for use on a great deal of RWD/AWD Nissan cars.
Find a site for GTR drivers and ask or give Motorex a call.
Old Oct 8, 2002 | 08:07 PM
rudeboy's Avatar
the LSD is from a type M R32
so it's RWD and the gear ratio in it is 4.363
Old Oct 9, 2002 | 05:47 AM
Differentials from a 4wd and 2wd are totally different, remember besides being up further on the drivetrain it also has to accept two sets of drive shafts for the front and for the rear, and when the rwd only cars only have one acceptance point for the drive shaft, so it wouldn't work.
The shifter works on most nissan cars because the transmission setup on the top is similar if not for any other reason.
And Type M R32 RWD only car, that should work, but I think the final drive is a little different, so expect some different types of speeds out there.
Old Oct 9, 2002 | 12:16 PM
rudeboy's Avatar
check this Import...
the Z32TT ratio is like 3.91~ sumthin
ours is like4.083
the type M is 4.363
wHich would essentially make the S13 faster
seem right?
Old Oct 9, 2002 | 02:02 PM
StanBo's Avatar
Differentials from a 4wd and 2wd are totally different, remember besides being up further on the drivetrain it also has to accept to sets of drive shafts for the front and for the rear, and when the rwd only cars only have one acceptance point for the drive shaft, so it wouldn't work.
Could you repeat that? I think there is a typo in there and I am lost.
Old Oct 11, 2002 | 04:19 PM
spitz7985's Avatar
AWDs have 3 diffs.
Old Oct 11, 2002 | 04:21 PM
spitz7985's Avatar
ours is like4.083
the type M is 4.363
seem right?
faster acceleration but slower top speed. i have no idea how much of an affect it will have.
Old Oct 12, 2002 | 09:12 PM
rudeboy's Avatar
thats ok cuz i'm not speed racin yet....yet
but i probaly will after i get more power
besides i could always compensate with diffrent rolling diameter
Old Oct 13, 2002 | 05:54 PM
Problem fixed, meant two, and they say three, which could be true to, but I know its was more than one
Old Oct 13, 2002 | 06:57 PM
spitz7985's Avatar
yeah. i'm not a top speed racer either. hard when we have limiters.
