plz help me on my sterling wheels??
hi
i have an question i have a 96 240sx i remove the stock sterling wheel but after that the air bag light come on the cluster i don't understand why it poping out anyone can help me thanks..
You're going to either have to get a s14 specific steering wheel hub, which comes with a resistor type deal which will allow your passenger bag to work and keep the light off, or you can just pull the bulb, or cover it with some tape or something.
Open the drivers door, and turn on ignition. Within 5 seconds, press and release the drivers door pinswitch 7 times, this will enter into diagnostic mode. Check the light for a code, and then turn ignition off. Repeat procedure, this will take it out of diagnostics and clear all codes.
