the resitors that are for sell on ebay
Are the speed resistors that are for sell on ebay any good? I am thinking of buying one for mine but am scetptical of buying on ebay. I clames 20hp gain and 130+ mph gain. have any of yall tried it or heard anything about it..
I bought the one on ebay...it was like 12 bucks so if it doesn't work, than no dissappointment here, ill let ya know in a few weeks what the verdict is...
man will it be sweet though to gain 20horses for 12 bucks, but all its doing is changing fuel/air ratio's and kicks in when the computer senses you stomping it, prolly burn a lil more fuel but owell |
bought it and will post on results when recived. seller said i should get it by mid week... paid 3.75 for it...
Sounds like a load of ....... to me, but I hope the best for you two! I just hope is doesn't damage the ECU in any way.
Driftmonster http://www.geocities.com/wardog5811/SR20det.html |
well if it does damage the ecu i have another and i also plan to get either a sr or a rb in the near future thanks for the input though....
I think you can buy one at radio shak for like 3ocents or sumthing like that, i heard it doesnt work either.
Ryan |
KA24de_510 at NICO did a $1.29 resistor mod and explained it here: http://www.nissaninfiniticlub.com/fo...&threadid=1018
The people who tried it said it had slightly better response and slightly better top-end power. Definitely worth $1.29. (or $0.99) |
I received the resistor like a month ago and i forgot to post about it. Well it is something you could pick up at Radio shack for 99cents, HOWEVER, you dont know the resist amount. The resistors are color coordinated so unless you can tell by the ebay picture you wouln't be able to get the one from radio shack. Also i installed it one morning on the way to school and the resuslts were about what i expected, a slight increase in power/response, and a change in high end
Now when your cruising in like 1rst or second slow, and you punch it, once my tach hits like 3000 and the computer senses the stompage, it changes the engine timing noticibly by a slight pause and then boost of power. I mean its not amazing nor should you use it against someone as having some major mod. but its awesome to have cuz it does increase your power when racing and improves high end for a cheap cost...Hope these details helped, so try it if you feel the need Casey |
It actually fixed a problem that I had with my revs droping.
When I take my foot off the gas the revs got stuck for like half a sec at about 1.8K and then went down slowly. Now the revs just drop like a normal car. To me it seems like it's running a little leaner. But I don't know. Thanks though for the mod. |
Hey I have the exact same problem with my engine reving and then slowly dropping, maybe I should give this a try too. Just to see what happens.
Resistor Value
Sorry, I meant to ask before but I am having a hard time finding the value of the resistor. I heard somewhere it is 4.7K Ohms but I would like to hear from someone who has actually tried it before I chance it. Thanks
