Black Signals?
boil the lamp in water for 5 mins, the glue will get very soft. pry off the lense with a few screwdrivers and your good to go. hopefully you can open the lights up if they are glued together, if not, they are probably plastic welded and will require you cut them open with a dremel, or just ditch the idea all together. i know the boiling method works with stock lamps, hopefully you can do it with custom ones aswell.
hey, smoked ambers looks pretty sexi, too. i kept my ambers just in case too so i can mess with the clears. i think the spray on with a clear coat is best cuz u can make it as dark as u want. (1-2 coats light or 7+ coats black)
