Bought a 95 240sx
Bought a 95 240sx (PICS)
Hello, I finally bought my 240 yesterday afternoon. Got it washed, clay bar, buff and what not. Going to be taking it to get tuned on Friday so i can pass emissions. Order a new magnaflow 3 inch cat, two days ago. So hopefully i can get it by friday. Also, going to get it alignment sometime this week. I hope for today, but looks like more or less on Thursday. Talked to a local performance shop, they recommended me to go with smaller injectors and smaller turbo for more of a friendly street car. Got to get it tinted and what not and a couple of things here and there fixed. Car ran good after I bought it, found out about the speed govenor while drving to the detail shop. But i got a couple of issues now. After i got it last nite from getting it detailed, the car was idling kinda high, between 1.5k and 2k, and also, when i would hit 5-6 k the car would start to sputter and not let me rev higher than that. Sometimes it would, like fisrt gear i could go to 6k, 2nd gear to 5k and so on. I am assuming they (detail shop) messed something up while they were cleaning the engine bay. Also, I hear like a whistling sound, the higher the rpm, the higher the whistle (not the turbo either). It sounded like it was coming from the passenger side. Also, i hear a ticking sound, so hopefully the engine isnt damage, just weird that it was kool before then. These are the mods that the car has:
S13 Redtop
S14 Transmission
3-puck Clutch
Knock off Greddy intake
Sard 850 cc injectors
Greddy Rocker Arm Stoppers
Garret T3 60-1 .70A/R Turbo
Z32 Mafs
Full Race Exhaust Manifold
Tial 44 mm V-band Wastegate
Innovative Wideband 02 Controller (LC-1) with data logging
Bosch Wideband Sensor
Fueled Front Mount kit
Koyo R Radiator
Dual 12" Electric Fan setup
Greddy Emanage Ultimate
R33 Differential (5 bolt axles -- thicker than S14)
Staggered 5 Zigen Pro Racer GNs (17X8.5 front and 9.5 rear)
Falken FK-451 Tires (235 series in the front and 255 in the rear)
Tanabe Sustec Pro Coilovers S-OC Type IIs
Greddy Type S Boost Controller
Greddy Type RS Blowoff valve
NGR Steering Wheel with quick release
Greddy Catch Can
Apexi N1 exhaust
Catco Catalytic Converter
Optima Battery
Greddy Turbo Timer -- needs to be properly installed
Optima batter relocated
Blitz boost gauge
Upgraded sway bars, not sure if whiteline or not, they are metallic blue in color.
Dupree subframe spacers
Energy suspension bushings throughout.
S13 Redtop
S14 Transmission
3-puck Clutch
Z32 Mafs
Koyo R Radiator
Greddy Catch Can
Apexi N1 exhaust
Optima Battery
Blitz boost gauge
