Hood Hinge Problem
Old May 27, 2005 | 08:54 AM
Roscutoo's Avatar
Hood Hinge Problem
The hood on my 240 shuts offcenter with the driver's side of the hood raised slightly. I found the problem to be the base of the hinge on the driver's side is lifting up when the hood shuts. I was just wondering if anyone else has had this problem and what they did to fix it?
Old May 27, 2005 | 09:12 AM
jpos985's Avatar
i got the same problem and i thought my hood was just warped a little from when i had it in my basement leaning on the wall while i swapped a newer motor in. i got the exact same thing.. the driver side of the hood sits up like a 1/4 on an inch its been pissin me off for a week!!
Old May 27, 2005 | 09:13 AM
jpos985's Avatar
have u fixed it? let me know if u figure anythign out i think ill just keep playin aruond with the hinges and see what happens
Old May 27, 2005 | 02:23 PM
GreenPunkBlood's Avatar
try new hinges, they cant be that much from a junk yard....
Old May 27, 2005 | 05:32 PM
Roscutoo's Avatar
It appears that the front of the hinge base is bolted down but the back is put on with some kind of adhesive. I guess mine finally just let go. Anyone know what you are supposed to use to put it back on?
Old May 27, 2005 | 05:36 PM
2fast4y0u's Avatar
jb weld maybe....i cant think of anything else that would hold it
positron
Jun 4, 2007 07:47 AM
peterm
Sep 19, 2005 02:35 PM
uvamosk
Aug 12, 2005 07:31 PM
badman70_1
Jan 26, 2005 05:33 PM
180sx
Oct 6, 2003 03:20 PM
