kouki tail lites wiring???
Old Sep 16, 2004 | 03:29 PM
Jedi Mind Gamez's Avatar
For those of you that wired them, how did you do it? Did you remove the females plugs off the stock ones and stick em on? or did you find a set of male plugs? or did you just skip the plugs and just wire the wires together?
Also when u connected the wires did you soder them or just twist them together?
And which wires go with wut? On the reverse lites it seems pretty straight forward green with green, black with black but what about the other ones?
Old Sep 17, 2004 | 12:50 PM
rudee023's Avatar
The wire colors pretty much match up. Just take the plugs from the old lights and put them on the new lights. Just use butt conectors from Home depot.
Old Sep 17, 2004 | 02:51 PM
not on mine they dont....
on the 240sx male end for the centermost light i got
black
red/green
red/blue
on kouki lite female i got
black
green/yellow
green/white
for the outermost lite on the 240sx male end i have
red/green
red/blue
black
green
for the kouki lite female end i got
black
green/yellow
green/white
green
im guessin the solid black and solid greens match up, but wut about the other ones?
and wut are butt connectors?
thanks
Old Sep 17, 2004 | 04:31 PM
sr180's Avatar
the wires that are actually connected to the houseing of the kouki tails are the same colors as the ones on the stock lights...all you have to do is cut the female clip off, and soder the female connectors from the stockers onto the kouki's its hard to see, but the wires match, or at least they did on mine, good luck
Old Sep 17, 2004 | 08:52 PM
thx....
i didnt really bother to look at the female ends since i figured they would be the same as the male....
BILLYhoang
13
Feb 17, 2008 03:26 PM
Indolent
Aug 10, 2006 09:08 PM
racesynergy
Jan 30, 2006 12:27 PM
neilstafford
Apr 4, 2005 02:54 PM
Top_Secret240
May 21, 2003 08:01 PM
