My latest project
Old May 2, 2005 | 11:01 PM
teampacman's Avatar
My latest project
SPEC SHEET/PARTS LIST
CHASSIS
- 1990 Nissan 240SX
- Nismo Motor and Tranny Mounts
- Promod Custom 12-point roll cage
- Jaz 10 gallon fuel cell
- Weldon fuel pump
- JDM S13 rear end w/4.10 final drive and custom oversize axles, Kaaz two-way limited slip
- Cannon Engineering custom driveshaft
- New OEM wire harness
ENGINE - SR20DET
- HKS Cams 272
- HKS Lash killer kit
- Greddy Valve Springs
- Crower Retainers
- Ferrea Custom Valves
- Greddy Rocker Arm Stoppers
- Toda Adjustable Cam Sprockets
- Cylinder head ported and polished by Mo Flo
- Apex’I 87mm head gasket
- Greddy 87mm pistons
- Greddy rods & wrist pins
- Golden Eagle sleeves
- Micro-polished and balanced crank
- New OEM Oil Pump
- New OEM Rear Main Seal
- ARP Main Bolts
- Greddy Head Studs
- Greddy Oil Pan
- OEM Main and Rod Bearings
- Greddy Electronic Boost gauge
- Greddy Electronic oil pressure gauge
- Greedy Electronic EGT gauge
- Greedy Electronic Boost controller
- Greddy Turbo timer
- Greddy Intake Manifold (ported by Mo Flo) w/custom 90mm throttle plate, Q45 throttle body
- Greddy Oil pan
- Greddy rear diff cover
- Custom Full-Race stainless turbo manifold
- Custom Fuel Rail
- Rochester 1600cc Injectors
- S15 5 layer exhaust manifold Gasket
- SplitFire Coil Pack
- Garrett GT40R dual ball bearing turbocharger
- 44mm Tial Wastegate
- 50mm Tial Blow-Off Valve
- Full-Race Custom 4” stainless downpipe
- Full-Race Custom stainless dump tube
- Full-Race Custom stainless exhaust manifold
- Apex’I GTR Type R Intercooler Core
- Apex’I 3” IN Tanks
- Six Burns 3" aluminum intercooler U bend piping
- Five Burns 4" exhaust piping
- Meziere electric water pump
- Koyo radiator
- Dual FAL fan's
- Blitz upper radiator hose
- Samco lower radiator hose
- Cosworth 5-bar MAP sensor
- AEM EMS engine management
- AEM WEGO wideband a/f sensor w/gauge
Some parts
This setup will also be methanol injected with its own 1gallon fuel cell, 1600cc injector and pump. The system will be set to kick in after 20pounds of boost
Hopping to make around the 800hp range at 30psi :thumbup:
Old May 3, 2005 | 10:00 AM
2fast4y0u's Avatar
ahhhhh thats wuite the list of parts.
good luck
Old May 3, 2005 | 10:04 AM
masterfubu's Avatar
how much did the cage cost?
Old May 3, 2005 | 10:13 AM
JoelB's Avatar
dude, someone stole your interior.
Old May 3, 2005 | 05:41 PM
CowboyTurbo's Avatar
why THAT color? what're your plans with the car? entering any races?
Old May 3, 2005 | 08:51 PM
Sirikool's Avatar
is that a Type-R cabinet i see in the 1st pic?
GL with ur project.
Old May 3, 2005 | 08:59 PM
LTSCUDRFT's Avatar
Re: My latest project
CHASSIS
- 1990 Nissan 240SX (Silvia)
it's NOT a silvia it's not even a coupe!
it's a 240sx. that's it.
Old May 7, 2005 | 12:32 AM
teampacman's Avatar
Some pictures of the block
Old May 7, 2005 | 12:51 AM
teampacman's Avatar
Re: Re: My latest project
And what was point in saying that?
Old May 7, 2005 | 01:10 AM
looks good so far, keep us updated
Old May 7, 2005 | 12:10 PM
Slidin240's Avatar
U got a nice project going here. keep up the good work
O and LTSCUDRFT sounds like someone is hating...
Old May 7, 2005 | 01:39 PM
silviadriver's Avatar
is this the same pacman that use to have a s2000 or a eg k20?
anyways, thumbs up for the fullrace
Old May 7, 2005 | 02:48 PM
teampacman's Avatar
Thanks alot
Old May 7, 2005 | 02:52 PM
teampacman's Avatar
Yes, it is and s2000 with ITB's and the K20 motor was in my CRX .
Old May 7, 2005 | 08:29 PM
LTSCUDRFT's Avatar
Re: Re: Re: My latest project
The POINT of saying that was so that you would know that you called your hatch a silvia, it's not a silvia it will never be a silvia even if it was a coupe, that is what i was saying. By the list of parts i thought you would know a little bit more about these cars than you do, if you look at my post ^^ I quoted you and it shows that you did call it a silvia, so don't act like I'm the idiot!
And Slidin240 I'm not "hating" I kinda like the cage, it's a little much for me but it's cool. And I have respect for any person who does the work on their own cars.
