My New S14 Silvia
9 Attachment(s)
Well I have a totally new ride but yes it is still a nissan. Here are a few shots of it. Sorry for the pics they were taken with bad lighting.
Attachment 28012 Attachment 28013 Attachment 28014 Attachment 28015 Attachment 28016 Attachment 28017 Attachment 28018 Attachment 28019 Attachment 28020 |
ok, can you explain to me why your left headlight is all taped up? I've been wondering about that now for some time and couldn't figure it out~ lol. Car looks good, but... more pics please!!! (with better lighting) btw, the vids you posted were good too, those are some friggin' FAST S13's you were racing.
is it taped or an air duct
yeah im thinking its an air duct
Looks hot! Where are the videos located at?
nice! :thumb: Pretty sure thats an air duct... isnt that the right headlight??
the x tapes are so that the lense wont crack under the immense vibration during races... as for the left side, it's air duct, looks like one mean serious motha fawker
looks real nice, plans for new wheels since you pulled the fenders? looks like a duct to the turbo inlet
Yea it looks good man, but i really liked ur purplish blue color too, either way its awesome with whats under the hood, good job:thumb:
Sleeperella- is right that way if my lenses break they will ideally stick to the tape, The right head light is an airduct I made works great. it is about 24" above the ground which gets it out of the range of baked ambeient air. everyone puts the little scoops in the bumper somewhere and scoops all the hot air the sun generates while striking the ground.
It is a fully built engine here is the list I will redyno today with a better tune last time I hit 526RWHP I am hoping to hit the same or little higher. Engine: Tomei Double valve springs Tomei Solid Lifters Tomei RAS Tomei 270 Cams with 12.5mm lift Tomei Adjustable Cam gears Tomei Stock bore pistons Tomei H-beam Con Rods Tomei Balanced Crank Tomei 1.2mm Head Gasket Tomei Oil Pump NISMO bearings NISMO water pump Greddy 7qt oil pan Sard FPR Sard 850cc injectors NISMO Fuel pump Drive Train: Emotion R R33 Transmission kit w/ shift kit R33 GT-R OS Giken cross mission w/ large input/output shafts OS Giken twin plate clutch R33 Propeller shaft R33 GT-R drive shafts NISMO 2 way LSD Peripherals/Misc; Greddy TD-06 25G 10cm turbo Greddy exhaust manifold Greddy Type R Wastegate Greddy Intake manifold (surge tank) Greddy Type R BOV Greddy FMIC 2 core 100mm Turbo inlet pipe Speed Factory One off Oil catch can Stainless steel Radiator overflow 3 Core Brass/copper radiator |
