my s13
Old Nov 17, 2002 | 08:42 PM
S13 Slide's Avatar
my s13
here's another s13.
tein ha's
trust fstb
recaro srd
heros 14x7 +10
enkei 92 mesh 14x7 +15
Old Nov 17, 2002 | 09:31 PM
I'm with Stupid's Avatar
That's a pretty nice car Steering wheel looks wierd as hell though. lol. Anyway I notice you popped up the rear of your hood all drift-style-like. I wanna try that out. How'd you do it, just a couple of washers?
Old Nov 17, 2002 | 09:34 PM
S13 Slide's Avatar
yeah i used 7washers and longer bolts, hehe i found the steering wheel on ebay, it was in a unopend package from the 70's. i plan on getting a nardi though
Old Nov 17, 2002 | 09:36 PM
rudeboy's Avatar
Hey S13...
sid you space the hood because of clearance issues with the strut bar?
stupid, i had to use a couple washers earlier on my hood. they didn't give me enough lift. you'd be better off using longer bolts and real spacers. put em beteween the hood and hinge
Old Nov 17, 2002 | 09:37 PM
rudeboy's Avatar
damn we posted at the same time!
Old Nov 17, 2002 | 09:44 PM
You guys never had issues with the hood latch did you? You know since the agle is different.
Old Nov 17, 2002 | 09:51 PM
rudeboy's Avatar
not that i've seen so far
Old Nov 17, 2002 | 09:52 PM
S13 Slide's Avatar
no issues from the latch, and i did it becuase i think it looks cool.
Old Nov 17, 2002 | 09:56 PM
Hehe I wanna do it for the air flow, since the hood/winshield area is high pressure it'll force air into the engine compartment.
Old Nov 17, 2002 | 10:00 PM
rudeboy's Avatar
i figured it would be the other way around. with the hood above the weather strip, the air going over the hood to the windshield would create a vacume. allowing the hot air to escape from that space.
either way it'll bring cooler air in
Old Nov 17, 2002 | 10:05 PM
Yeah I thought the same exact thing until I read an arguement about it. It's just how the vents work in your car. The air enters at the base of the hood into vents then to you in the seat. since the air there is higher pressure than in the front that's where the air would enter. I guess it'd be good for something like an oil cooler
Old Nov 17, 2002 | 10:13 PM
rudeboy's Avatar
i forgot about those vents.
so when the air is forced into the engine bay where will it go?
cuz at the same time that is happening the air from the front of the car is also comming in. thats why i figured it would work oppisit of how it does
Old Nov 17, 2002 | 10:18 PM
I figure it'd just go straight down the firewall.
Old Nov 17, 2002 | 10:19 PM
rudeboy's Avatar
sounds right to me
Old Nov 18, 2002 | 07:42 AM
Import Fanatix's Avatar
14" rims, tight!!!
Do you have any closeups of the rims on the car.
What size tires do you have on? My boy was thinking of throwing on some 14's on his whip.
