My stockish engine
My stockish engine
engine bay... pretty stock looking except for the 8.5mm wires, short intake, and the generic strut tower bar... everything else is inside
Anyhow, after painting the valve cover, I felt like sharing a pic
You should've seen it when I brought it home from Arizona, where I bought it. Looked like a mudbath.
That picture is the result of 3 cans of engine degreaser, 3 different steel brushes, Simple Green, a bunch of rags, Armor All, belt dressing, and about 3 hours of hard labor.
The painting part took about 30 minutes, not counting drying time
On a side note, the interior was also so dusty, it reminded me of the beach on a windy day. I also cleaned everything in there... practically ripped the entire interior out and cleaned each part piece by piece. I guess I'm one of thse car guys.
When I initially bought the car I liked how the interior was pretty complete, and the engine was running really good. But - it was super dirty everywhere! Now it's just the paint that I don't like, but in due time...
If the seller saw the car now, he'd probably regret selling it to me for $4100
Definately a clean engine bay rainy, well done. I bet you put quite a few hours under that hood! Paint matches the strut bars, did you paint that as well? You did a great job on the valve cover, like how the Nissan still shines. What paint did you use?
Keep the pics flowin!
Dr.
Dr.
After I took the valve cover off, I hit it with a steel brush to loosen up all the gunk on it (there wasn't much since I had cleaned the engine when I first got it) spray-cleaned it with brake cleaner, rinsed with soap and water, then towel dry. I must have sprayed about 2 loats of primer then about 5-6 coats of....
Krylon.
Yup, old reliable Krylon. I know they have high-temp engine paint out there, but I used Krylon on my last car and it worked perfect! I had 2 cans of paint for the job; when I reinstalled the valve cover I noticed the strut tower bar looking plain, so I painted the rings on it as well.
Krylon.
Dres240
Apr 16, 2009 09:16 PM
Plastic Phork
Mar 14, 2005 03:59 PM
SilviaJai
Sep 23, 2003 07:36 AM
