picked up an s14,its definitely a little different, needs some stuff, check it out
Old Aug 28, 2009 | 12:58 PM
USMCDrifter's Avatar
Originally Posted by alex_s817
thanks. can anyone confirm that i can run 2jzgte spark plugs? i picked some up yesterday but id like to make sure first.
Why would you pick up 2JZ plugs, you have a 1j . . .just take em back (send em back?) and get some 1JZ plugs. There may not be much of a difference but I wouldn't chance it.
Old Aug 28, 2009 | 01:02 PM
240smoke's Avatar
plugs arent something you should be messing around with. I can understand getting the 300ZX fuel filter which it looks like you have already.
Old Aug 28, 2009 | 03:41 PM
alex_s817's Avatar
i was told on supraforums that the plugs are interchangeable. obviously i wouldnt just buy them on a whim. its hard to find the oem plug specs since this engine never came in a us vehicle
Old Aug 28, 2009 | 04:52 PM
240smoke's Avatar
Didnt the 1JZ come in the second gen supra???
Old Aug 28, 2009 | 05:22 PM
alex_s817's Avatar
not here in the us, the 2nd gen came with a 7mgte. In japan it did though, and many people do swap them into their US mk3's and sc300s. Its alright though i called boostlogic, titan motorsports, mvpperformance, and a few other big name supra shops to make sure. they all said i can use the mkiv plugs so i should be good there.
Old Aug 28, 2009 | 05:26 PM
240smoke's Avatar
I know nothing about supras except they are badass. I installed an HKS FMIC on one. thats the extent of my knowledge.
Old Aug 28, 2009 | 05:31 PM
alex_s817's Avatar
its all good, it definitely sucks trying to figure out everything that can be used from the 2jz's though. I wish i could find some writeups on this swap so I could see where everything is run by someone who actually does a good job. I did a lot of cleaning up today on the car, got rid of a cheap *** faze wideband, a pointless engine start button, a ricer fan switch, and all the wiring that went along with it. also disconnected the emanage and began looking for a new mounting location. im going to go through each wire and makes sure the connections are all correct and strong/soldered. i think im going to mount it next to or on top of the stock ecu and then make a sheet metal kickpanel to protect them. the turbo would have been off, cleaned and painted, re-installed and clocked, and with a new oil return today if it hadnt started raining. i work on this thing in an open parking lot, sucks.....
Old Aug 28, 2009 | 05:36 PM
240smoke's Avatar
that does suck. Im telling you man, polish that intake manifold and turbo. **** would look sweet. I even made a DIY on how to do it.
Old Aug 28, 2009 | 06:32 PM
alex_s817's Avatar
hmm the intake mani i might do, where is this right up? hah ill prob try it out, thanks
Old Aug 28, 2009 | 06:35 PM
240smoke's Avatar
https://www.s-chassis.com/forums/how-tos-installations-48/diy-polishing-metal-46292/
Old Aug 29, 2009 | 12:17 AM
  #26
carps13guy's Avatar
welcome, it looks like a good start of a project car. clean up the engine bay, the hackery the previous owner did to it, & paint her & it'll be a nice project car. good luck with it
Old Aug 29, 2009 | 05:29 AM
  #27
alex_s817's Avatar
thanks. thanks for the link 240smoke
Old Aug 29, 2009 | 08:37 AM
  #28
carps13guy's Avatar
nice abondoned project car. clean her up & make it your own. btw if you have a oil temp gauge & dont want it ill take it off your hands. good luck
Old Aug 29, 2009 | 02:39 PM
  #29
shiftred.'s Avatar
besides the paint i like the car. just get the car one color, clean the engine bay up and the car would look really good. You could take one of the spark plugs out of the motor get a part number and go to your local auto parts store.
Old Aug 30, 2009 | 11:08 AM
  #30
alex_s817's Avatar
thanks guys. s13 guy, i do have an oil temp but as of now i wanna hold on to it. it seems to work well and just dont have the extra money to upgrade right now. if i change my mind, u will be the first to know.
thanks shiftred, yeah i know. i spray painted the trunk black this morning. I sanded,primed, sanded, and sprayed and even though i thought it was going to come out great, it ended up having lines in it where you can see my paint patterns. im not sure if this is because i dont know how to paint body pieces well, i used cheap paint, the humidity, or a combination of all these factors. oh well, it looks better than before, and ill eventually have the whole car re-done in black once i can save for a vertex or origin kit.
