Randy's RB20 Hatch
Old Sep 28, 2007 | 05:51 PM
DriftX's Avatar
Randy's RB20 Hatch
Hey what's up guys? I haven't been on in a while since school started and I've been working non-stop on my project.
Lot's has been done to the car in the last few weeks. The KA is long gone and the Rb20 now sits and is running!
The setup:
No A/C
No P/S
RB20DET - pretty stock swap
New clutch, new bushings, new fluids, front mount intercooler, 11psi, full 3in turbo back exhaust!
To do:
Hook up z32 filter, r32 fuel pump, adjustable fuel pressure regulator, check for some more vacuum leaks - starts kinda rough, finish up taping the wiring and tucking it away, find a way to make the steering shaft clear the exhaust - impossible!?, bolt on driveshaft, bleed clutch, add some more coolant, and drive the hell outta it!
heres some pix:
Old Sep 28, 2007 | 05:55 PM
i have worked on a few rb20s.. i love how they sound with no exhaust lol
Old Sep 29, 2007 | 01:21 AM
S13_RB20's Avatar
Nice swap. Any problems with starting it when it's cold?
Old Sep 29, 2007 | 05:29 AM
Bumnah's Avatar
looks good. hope you finish it up and get to drive it.
Old Sep 29, 2007 | 01:35 PM
DriftX's Avatar
No not really, it spins over super fast, sputters for a second, then runs fine. And yes I do have my orange 'choke' wire hooked up. It seems like it barely getting enough fuel pressure. Im sure the r32 pump and better filter will help a ton!
If all goes well, it should be running and driving in a week or 2. The exhaust is going to be a *****. I have an aftermarket 3in turbo elbow with a screamer pipe, cool for performance, but its going to take some work to make it not hit the steering shaft.
Old Sep 29, 2007 | 04:42 PM
HKST04Z's Avatar
looks good man, pretty much the same set up as mine, lemme know how she runs
Old Sep 30, 2007 | 05:08 PM
DriftX's Avatar
Anyone know where i can pic up some electric fans for decent price? I can get some at autozone, but they are crappy and don't flow enough cfm. Also, do you know where i can pick up an assortment of the vacuum lines that run on the intake manifold, a few of mine are cracked!
Old Oct 2, 2007 | 02:33 PM
DriftX's Avatar
I got alot done today. I got my z32 filter on, skyline pump is in and working, the car is charging!
Just waiting on the exhaust to come, driveshaft bolts, bleed the clutch, e-fans and remount the bumper.. somehow
Old Oct 2, 2007 | 04:31 PM
HKST04Z's Avatar
coolio, get some more pics up when ur done =)
Old Oct 2, 2007 | 08:57 PM
Looking good!
Old Oct 2, 2007 | 09:08 PM
yarou's Avatar
Looks good man, keep it up. You can get a set of altima fans for about 60 bucks on zilvia, but keep an eye out for taurus fans because they pull a LOT more cfm than altimas.
Old Oct 2, 2007 | 09:12 PM
Sweet man. Does that intercooler not fit? It looks good to me.
Old Oct 2, 2007 | 10:20 PM
HKST04Z's Avatar
one thing you can do to help with your power is swap the i/c pipes so the hot pipe is going between the radiator and the cold pipe comes in on the right side and goes to the intake manifold
heres how i set mine up
theres a slight difference in power as well
Old Oct 3, 2007 | 12:29 PM
Dude thats nuts as ***** lol.
Old Oct 3, 2007 | 03:40 PM
TypeX180's Avatar
yeah, thats different...but, if it works it works
