rear fender folly
Old Aug 9, 2005 | 04:47 PM
Abdukted's Avatar
rear fender folly
well after years of readin i never realized that u cant replace the rear fender, u have to bondo it, right? dats not cool but whatever works. if im wrong tell me thanks.
Old Aug 9, 2005 | 05:03 PM
Fast1One's Avatar
Well...you can use rivits...or weld it if its metal, then smooth it out. Bondo is just to fill in holes/imperfections not to actually put the quarter pannel on...
Old Aug 9, 2005 | 05:27 PM
steve 14's Avatar
yes you can replace the rear fender
but not in your drive way
Old Aug 9, 2005 | 05:47 PM
Fast1One's Avatar
Betcha I can
Old Aug 9, 2005 | 05:53 PM
depends on the model, the fastback is the only 240sx with replaceable fenders. on coupes the fenders and roof are one piece so you end up laying the wide fenders over the stockers and cut around the wheel well.
Old Aug 9, 2005 | 06:41 PM
Fast1One's Avatar
^^^I think you have to do that with fastbacks too....
Old Aug 9, 2005 | 07:07 PM
steve 14's Avatar
Originally posted by Fast1One
Betcha I can
well you could but with body panels it's better to leve it to the pro's
Old Aug 9, 2005 | 07:11 PM
Fast1One's Avatar
Why? The only thing I wouldnt mess with is the paint....
Old Aug 9, 2005 | 08:01 PM
Abdukted's Avatar
yea i knew fasho i couldnt take them off i was scrapin bubled clear coat off and i noticed that it was one piece, yuck, oh well tho i still want some sick wide fenders for the front n the back
Old Aug 9, 2005 | 08:03 PM
Fast1One's Avatar
Good luck with that...post pics when your done
Old Aug 10, 2005 | 02:47 PM
steve 14's Avatar
so you want to cut out a fender thats part of the structural design and weld on a new one
yeah i'm going to leave that to the pro's
Old Aug 10, 2005 | 04:18 PM
Fast1One's Avatar
What can I say...Im ambitious
Old Aug 10, 2005 | 06:44 PM
steve 14's Avatar
haahha
Old Aug 10, 2005 | 08:25 PM
Abdukted's Avatar
yea good luck with that id like to watch but i dont know bout doin it myself im still sucha newb
Old Aug 13, 2005 | 10:36 AM
wikd240's Avatar
quarter panel replacement aint all that bad... and as far as the structural part of the car... you are only removing the damaged outter skin not the whole inner structure as well... if you are just adding the wide body fenders then yo leave the stock sheet metal alon and overlay the fiberglass onto the stock sheet metal... cut the metal quarter panel wheel opening out and you are set to go...
if you want to get fancy and have some skills with fiberglass and bondo you can even make an inner fender skirt to hide the old sheet metal of the factory fender... but that is getting into the hard core stuff and takes a lot of time and work... if i ever get my wide fenders im going to build the inner skirts... but that wont be till this winter some time...
